Joe Batt
Bronze Member
I recently bought 20 acres with the plan of making hay now and transitioning to pasture as my flock of sheep grows. First thing I did was look for help.
The seed guy suggested tilling it up, because the field had been plowed about 5 years ago and was very, very rough (like too rough to using a normal mowing speed with my 30 hp tractor and 5' rotary mower). I had a farmer run the disk over it 2 passes, wait for it to dry, 2 passes wait for it to dry, then another peice of equipment that I think is similar to a giant clutipacker. This equipment was all huge ag stuff; dually 4x4 John Deere articulated tractor. It was much smoother at this point. The dirt clods varied from softball to smaller. I can drive the tractor in road gear over most of it now.
Then I planted it with a 8Ft Brillion Grass Seeder. It took about 16 hours of seat time. I had to make 2.5 passes to use up all of the seed. The family picked up rocks for about 3 hours, filling my hay wagon. We picked up everything that we saw larger than a softball. I'm sure we missed some.
...two months pass...
Now the weeds outgrew the alfalfa, so I had a hay guy come bale it. First he called and told me there are too many rocks in the first two laps and he couldn't use the haybine. He had someone else mow it with a disk mower. He claims they had to change the blades 29 times (surely I misunderstood him, right!?). He will only bale the minimum that I need for the sheep, because he says it's too rough for his rake.
Is that adding up? It does sound like leaving the cut, unraked weeds will be fine. I may run the rotary mower over it this fall. Next year, I'll look for someone with a sickle bar mower instead of a haybine. I am assuming that mowing it taller wlil be easier on the mower and the rake (and he may not be able to adjust the haybine).
Anything else I should do to make the field better? It's going to be hard to find these rocks and smooth the field without tillling it up again and I'm not looking forward to buying more seed.
