New Zetor home!
   / New Zetor home! #1
BarryinMN
Platinum Member
Minnesota
JD, Allis-Chalmers, Zetor
New Zetor 4341.1 SR is home! Owners manuals are an easy read the service & parts binders are likewise straightforward. Loader hydraulics seem very fast & responsive. 2nd seat has a seat belt. Machine has an extra secret safety feature - pull up on the PTO clutch lever (disengage) to start. 3 gals of oil in engine, 17 gals of 80-90W in trans/hydraulic 32 gal fuel. Window washers front & rear. With rear wheel weights machine tips the scales a little over 10,000 lbs. Push button FWD & rear locker on the dash. Machine has a mix of lights including cab interior & euro style side running lights. Taking cell calls in cab is ok - always had to shut down the Allis or JD A. Very stable on side slopes Tool box has cat1 bushings & an air hose for the tires 4CFM & 85PSI. Euro style quik tach for loader is easy color coded hose connectors. Only thing not figured out is the 3rd key. Large one for ign, rounded for doors, 3rd??
   / New Zetor home! #2
would the third key be for the tool box, maybe the back lid on your cab, wheel locks? Got to be for soemthing. BTW, nice, nice looking machine.
   / New Zetor home! #3
Hi Barry,
Nice looking setup.
I think I could give it a good home also /forums/images/graemlins/cool.gif!
What kind of a deal did you get?
Yooper Dave
   / New Zetor home! #4
Barry, awsome machine. Man, could I use that grapple bucket right now. Have you tried it yet? Was that a bolt on kit, or come from the factory as a complete unit? Hope you have many yrs of enjoyment out of such a fine piece of equipment.
pete
   / New Zetor home!
Grapple is actually a rock bucket with euro quik tach from a local welder. They make various trailers including dumps & Bobcat attachments. This is his newest version with reinforcement across the front to reduce bending. The double cylinders reduce grapple bending if I grab something in one end only.
www.midsotamfg.com
   / New Zetor home! #6
Barry, Beautiful machine! /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif I think you will be favorably impressed with the power of the FEL. Show us some pictures of your machine working, when you get a chance.
   / New Zetor home! #7
barry what hp is that beauty and if oyu dont mind what did the hole package set you back im looking at one that size fwd cab and fel.
   / New Zetor home! #8
My guess is that you will have to find a different person to get an idea of what to pay. This thread is almost 4 years old and things have not gotten cheaper in that time frame.:)
   / New Zetor home!
Wow has it been that long??
Pricing is really obsolete as the 62hp non turbo motor is NLA. I think the smallest new now is 67hp turbo. The new machines have some nice updates. The one I recall is a fancier Grammar seat. They also relocated the exhaust stack back to the side of the cab so it might make maintenance access tighter.
It uses so little fuel I've never bothered to measure it.
As far as repairs the dealer replaced the battery under warranty. This year the clutch slave cylinder went bad, cost like $50 & took 45 mins to swap out. Also replaced the rear window - it didn't survive being hit with a melon size rock. Cost was $178 & took longer to vacuum out the glass than install it.
Here is a picture of the newest attachment. I've been using an 8' snow bucket but the neighbor made me an offer I could not turn down he no longer has a tractor large enough to run it.
   / New Zetor home! #10
man your right ididnt even think to look. any way howd the fwd drive work ive seen the sales brocure to say limited slip?
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
