nh tn75s shuttle code 63
   / nh tn75s shuttle code 63 #1
pete c
busselton western australia
new holland / john deere
hi I have a tn 75 s with an error code 63 poping up and the shuttle drops to neutral when you shift from turtle to rabbit need to turn off and restart to move
any ideas??
   / nh tn75s shuttle code 63 #2
I have a TN75s as well. I think there must be an inherent problem with the ECU for the shuttle. They replaced a switch under the seat and so far so good. I also had to turn it off and restart to get it to move....until I by chance figured out that I had to put it in gear and engage the shuttle lever.....all with the clutch pushed in and then let the clutch out and it worked fine. I could not put it in gear with the clutch out and then move the shuttle lever into forward or reverse and have it move. They replaced the switch under the seat and now it works normally. You might try putting it in gear, depress the clutch and engage the shuttle lever with the clutch in and then let it out and see if you move. Just my experience. Hope it helps....worth a try anyway.
thanks
this does a similar thing works ok till you go to rabbit then shuts down
harry k has some good input about a pressure switch which sound like its on the money will let you know if it works
pete c
just fitted new hi lo position switch and problem solved
thanks
2022 Ram 2500 (A55973)
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
2005 Kobelco 135SR Hydraulic Excavator (A56857)
2005 Kobelco 135SR...
Mini Excavator Quick Coupler (A55272)
Mini Excavator...
