No drive when clutch depressed on B2920 HST
   / No drive when clutch depressed on B2920 HST #1
ericher69
Ontario Canada
2008 Kubota b2920
Does this make any sense?
The HST drive does not work when the clutch is depressed on the B2920!
Released the clutch and bingo! Is this a safety feature?
I thought the clutch was for the pto engagement only
ericher69
   / No drive when clutch depressed on B2920 HST #2
Come'on now, this isn't funny...
   / No drive when clutch depressed on B2920 HST #3
That is the way it is. On the "B"-s the clutch disengages the drive to the PTO(s) and the wheels. I don't know if that is for safety or not. It does so I guess that the drive is not engaged while shifting from Low-Med-Hi. The independent PTO stays on while the clutch is depressed, the live will not.
   / No drive when clutch depressed on B2920 HST #4
On my B1750 HST the clutch is used when engaging the PTO, when switching between 2WD and 4WD and also when switching between high-range and low-range. I gather the high/low range selection is just a mechanical drive gear that changes how the power coming out of the HST is applied to the wheels. Just like a manual car you need to disengage the engine with the clutch to change gears but in this analogy the HST drive is the "engine".
   / No drive when clutch depressed on B2920 HST #5
It came to me as a drastic alteration from my previous experience with a BX. No clutch on the BX. I hope the clutch is a better system on my B2620 or in your case 2920 but it seemed odd going back to a clutch system on an HST.
   / No drive when clutch depressed on B2920 HST #6
ericher69
Granted I haven't had a real tractor for very long, but I can't figure out why you would want to operate the HST drive with the clutch depressed. I'm imagining you want to stop a pto driven implement briefly to reposition the tractor? If so, disengaging the PTO is inconvenient?
   / No drive when clutch depressed on B2920 HST #7
Depressing the clutch disengages all power to the drive train, including the HST, PTO, HI-LO, 4wd etc. The HST will not operate with the clutch depressed.
It's like a car....no clutchy, no movey :D
   / No drive when clutch depressed on B2920 HST #8
Yep, I get all that. Now why is that a problem? That's what I don't get.
   / No drive when clutch depressed on B2920 HST #9
ericher69
The clutch cuts off engine power to the transmission. Not a safety feature, it's a clutch feature.
Can I ask why you thought otherwise?
   / No drive when clutch depressed on B2920 HST #10
Disengaging the hydro with the clutch is a nice feature when starting the unit in colder climates!:D
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
Rhino DB150 (A57148)
2005 Ford F-450 Pickup Truck, VIN # 1FDXF46P65EB16866 (A57453)
2005 Ford F-450...
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
2014 PETERBILT 388 (A58214)
2014 PETERBILT 388...
CAT IT18 (A55272)
CAT IT18 (A55272)
