No PTO and only drives with the diff lock engaged
   / No PTO and only drives with the diff lock engaged #1
marchtransport
Lincoln,CA
Ford 445
Thank you for your time. I helping a friend who has a MF 3545, 2WD. It will only drive with the Diff Lock engaged, and the PTO doesn't work. I'm guessing the PTO clutch is gone and he doesn't need it anyway. will it hurt anything to operate (mostly disking, flat ground) with the diff lock on all the time?
Thanks again for reading
   / No PTO and only drives with the diff lock engaged #2
Sounds like a broken axle to me. When you engage the differential lock, you now have the non broken axle pulling the tractor forward.
   / No PTO and only drives with the diff lock engaged #3
Why would the pto clutch affect it not driving on one side? I'm thinking with the info given, I'd be looking for a broken axle or stripped spline on one side.
And NO I wouldn't run it until I found out if broken parts or metal is floating around inside!
SR
   / No PTO and only drives with the diff lock engaged #4
SR
I am thinking the PTO not working is yet another problem.. I still think the axle is broken or like you said splines stripped, which amounts to "broken"
Thank you guys- I appreciate your responses.
   / No PTO and only drives with the diff lock engaged #6
You are kidding right ??? Please tell use you were kidding.
TractorData.com Massey Ferguson 3545 tractor information
No not kidding- Thanks for the responses
   / No PTO and only drives with the diff lock engaged #9
Any 2WD tractor with the differential locked does not turn corners without slipping the rear wheels.
I would not recommend driving in diff lock with one this big. :thumbdown:
Thank you- took the advice and parked it and put it up for sale. Someone might want it to repair, or for parts
Thank you again
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2010 Chevrolet Equinox SUV (A55853)
2010 Chevrolet...
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A57453)
2017 International...
UNUSED JCT DB500 DUSTLESS BLASTER (A57193)
UNUSED JCT DB500...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
2018 Ford F550 Chassis (A55973)
2018 Ford F550...
