Not tractor related, but still hydraulic
   / Not tractor related, but still hydraulic #11
The air motor on my hyd jack works from start to finish, and has springs to pull the shaft back down.
The one I have is a 20 ton and cost me about $80 several years ago. It is kind of slow.
JJ
The working pressure is about 2,000 so not super high, at least that one. Thanks for the info on the air over jacks, they are a low cost option.
Speed isn't super important, since the travel distance is short, and I have no plans for high production volume. I suppose I COULD start with an air over jack, and make it work, just to see if the whole thing will work out likre I imagine, then if it does invest into the elec option.
How thick of an H frame would I have to build to hold up to this thing? I believe the dies I will be using would give way before the thing reached 20 tons, most likely way before.
   / Not tractor related, but still hydraulic #13
2019 Deere 550K (A53317)
2019 Deere 550K...
2012 FORD F-450 FLATBED (INOPERABLE ) (A58214)
2012 FORD F-450...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58216)
2019 MQ POWER...
1994 CATERPILLAR 936F WHEEL LOADER (A52709)
1994 CATERPILLAR...
JCT 72" Skid Steer Rotary Brush Cutter Attachment, Asset# 68 (A59076)
JCT 72" Skid Steer...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
