OK. I get it, but which winch?
   / OK. I get it, but which winch? #1
hrcarver
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
I'm thinking this one Superwinch 12V DC Electric Winch — 5000-Lb. Capacity, Model# S5000 | 5,000 - 7,900 Lb. Capacity | Northern Tool + Equipment for $400 shipped on amazon, not much more than a decent hand winch. 5k ought to load most of my stuff, especially with a pulley block. Seems light enough to be portable and (if I understand correctly) just plugs up to the trucks trailer plug for power?!?!
Did I read that power source right? Would save me having to buy another battery every other year if true.
Is the 5k rating rolling or dead weight?
   / OK. I get it, but which winch? #2
There is no way you are going to pull anything with it connected to the trailer plug. Mine has a 30A fuse from the factory.
Here is the amp chart for that winch:
Motor
Load Speed Current
lbs. kg ft/min m/min Amps
0 0 17.0 5.1 15
1,000 454 12.5 3.8 70
2,000 907 9.0 2.7 117
2,500 1134 7.5 2.3 155
3,000 1361 4.5 1.4 220
   / OK. I get it, but which winch? #3
Another reason IMO. Country bumpkin setup is TOP Notch.
WVpolecat Born in Montgomery and still have the Farm in MT.Nebo :D:thumbsup:
Carey
   / OK. I get it, but which winch? #4
I run mine with a 2 AWG wire from the battery and grounded to the frame. It is a 3500 lb winch, and the wiring came with it.
   / OK. I get it, but which winch? #5
Read the specs in the PDF file: http://www.northerntool.com/downloads/manuals/14154.pdf
That rating is dead load and not rolling load, rolling load for that model is up to 22k lbs up a 10% grade, it can pull over 5k straight up a 100% grade.
Also, it does need to be wired directly to your battery with a minimum rating of a 60 amp alternator and battery with at least 440 cranking amps. I don't know why they have "Uses 7-hole plug-in connector" in the additional specs but it's certainly not for power...
   / OK. I get it, but which winch? #6
Here is a very good connector for use with winches and jumper cables or other high load sources. You can mount one to your tow vehicle and another to the winch and just plug them in when needed.
Dual Power Cable Link Connectors
Dang! I thought that was too easy. Problem is I'd have to wire up EVERY tow vehicle. Pain in the :ashamed: Take all freaking day for the farm trucks.
So what the heck is the 7 pin for???
   / OK. I get it, but which winch? #8
What I did was loose the battery and make a plastic block out of cutting board material and put two lugs on it, + and -. They are wired to the winch and I just use my jumper pack to run it. Has plenty of power and can easily load heavy stuff. I had to load my neighbors GM truck 3 times in one day and never strained.
Chris
   / OK. I get it, but which winch? #9
Chris
Neat solution. Which jumper pack do you have? I'm looking for one now.
Chris
Seeing how the wires and hookups are going to be over $100 on each vehicle, not a bad idea. Which one you got(and how long have you had it)?
PALLET OF ANGLE, CHANNEL & FLAT IRON (A52708)
PALLET OF ANGLE...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
(2) JOHN DEERE 8 LUG RIMS (A52708)
(2) JOHN DEERE 8...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2005 John Deere 200C LC (A55272)
2005 John Deere...
