stumpmj
Hi everyone,
I’ve been lurking for a while and I’m finally getting close to pulling the trigger on a small tractor; either a Kioti CK2610 or a Kubota L2501 (going round with quotes and trying to make a final decision). The planned usage is 350’ long gravel driveway maintenance (box blade or land plane), putting in a large garden (tiller), fence building (3 point PHD), planting trees (PHD and backhoe), adding some small drainage ditches (backhoe) to reduce standing water around the property, and general household tractoring stuff.
What I’m unsure of right now is what options to get. So far, I’m planning on a loader with a QC bucket and a backhoe. What I’m unsure of is what other options I should be considering. Here’s the current list I’d love everyone’s input on:
Remotes: I know I need to two rear remotes for the backhoe; a spring return and a detent. Given my planned usage, is there any reason to get a third?
Loader third function: no plans for anything like a grapple right now as we don’t really have much brush to move. If I change my mind later, is it terribly difficult to it later? I’m mechanically inclined (I can rebuild an engine as an example) but haven’t had a tractor before. I’d much rather hold off on ordering for now unless there’s a compelling reason to order from the factory.
Backhoe thumb: leaning towards a mechanical thumb because I can see where one would be super handy but I’m trying to compromise on cost vs a hydraulic thumb. Good/bad plan?
Canopy: I’m getting one but I’m unsure if I’m better off ordering from the factory or aftermarket
Is there anything else I should be ordering?
Thank for your input! I’m looking forward to sharing projects with you as we get going with them in the spring.
