Parts for Troybuilt Horse tiller
   / Parts for Troybuilt Horse tiller #1
ranchome
Piedmont, Mo
19?? Troybuilt Horse tiller
I am in need of a front driveshaft bearing for my Troybuilt horse. I've tried Troybuilt and Jack's Small engines. Both say are not in stock on their websites. Does anyone know a good source for OEM parts for these old faithfuls?
   / Parts for Troybuilt Horse tiller #2
If you can get the number off of the old bearing, you might be able to get it at NAPA, etc.
Thanks Brian, I was thinking of doing just that, but I didn't want to pull th old one out until I'm sure I can't get an OEM replacement. I have a feeling that item may have been discontinued when MTD took over Troybuilt. But I'm still gonna hope!
   / Parts for Troybuilt Horse tiller #4
Thanks oldmanmike. I did end up getting the bearing and seal from Napa. The bearings are marked with the Timken #'s so it was an easy match. The seal we just measured the shaft diameter and the cup diameter to find a match.
2) bearings (front and rear)
1) seal
gear oil
Total $26.50
No shipping, and I have them today. Napa showed drive belts available but couldn't tell me if they were a matched set or not, so I ordered them from Troy-built.
Thanks again for your help.
Just an update on my repairs. I installed the new front and rear main shaft bearings and seals yesterday. Everything went great until i went to reassemble the shaft. When I put all the shims in I still had bunches of endshaft play. Turns out the rear worm gear (drives the tines) and the adjacent spacer has worn a lot on the sides. I believe this was caused by not enough gear lube in the transmission. It was lower than the connecting tube level. So now I have to replace the rear worm and it's spacer.
I bought this tiller off a local fellow who said it ran great, only needed the belts tightened, (right) but since I only paid $50.00 for it and the engine started first lick I knew I'd be ok. Right now I'm into it a little under $100.00 so after I get the rest of the repairs done (thinking the gear lube was low due to leaking wheel axle seals, so I'll need to replace them) I believe I'll have a little under $200.00 invested. Not bad I think.
   / Parts for Troybuilt Horse tiller #7
I would probably run into the same problems if I have to do the same, so thanks. I think it's worth it to go ahead. My Horse-1 runs great, even though it has minor problems.
2025 KG43 UNUSED Chain and Ratchet Binder Set (A50860)
2025 KG43 UNUSED...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
