Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,511
So far global warming is doing a good job for us in West KY. Normally I pull off the bush hog after the first killing frost and put on the blade for the winter since we live at the top of a big hill but the other day it hit me I have not for the last 5 years. Typical the snow melts off on its own quickly but if it takes a few hours the Subaru Forester turned out to be a snow weapon out of this world.
   / Pictures of your snow weapons #5,512
I don't have access to a dial indicator, but there enough wobble in the fan shaft to see it visually.
I hope they come and get that snow blower and give you a complete refund so you
can purchase a pronovost snow blower and do not charge you for picking it up as
they should not charge you anything period.
There should be no wobble/elliptical orbit period in a 2 stage snow blower.
The wobble indicates the steel is too thin for sure.
Calling mk martin may not do you any good as they do not like to listen-been there
done that when I tried to get them to build me a single stage snow thrower with a
13 inch snow blower rotor as the 16 inch rotor models they make are much, much
to large for sub compacts or compact tractors of any brand.
   / Pictures of your snow weapons #5,513
I'm hauling it into the dealer that I bought it from, ordering snow equipment now it's kind of a moot point, it won't be delivered until new years or later I anticipate? If the can make this right before snow falls, that will be fine. I like the build quality of the snowblower, minus the axle wobble. Just a lack of QC routines it seem? Can happen, just hope there is no runaround.
   / Pictures of your snow weapons #5,514
I'd be tempted to put a small inconspicuous mark on the bent shaft so that you can tell if it's been replaced or just straightened.
   / Pictures of your snow weapons #5,515
If you don't mind a retired mining equipment mechanics insight;
The wobble being the existing elliptical orbit of the impeller goes all the way back to the rear
impeller housing making it flex and it should not do that period.
1. the steel is too thin
2. the welds will be weak due to the thinner steel
3. the damage to the snow blower will continue to become larger and the rear weldments that
support the bearings and the gears will start breaking at the impeller shaft hole in the weldment
and then the weldments for the cross shaft.
I only want to help you TYMNorsky not get in your way.
I would ask for a refund and call Pronovost and pay for a snow blower and have it shipped to a Pronovost dealer near you by AMTRAK freight
or order one from Paul Vanderzon at Deneigement Vanderzon and have it shipped by amtrak to the nearest AMTRAK station depot.
I consider Paul a good friend and an honest business man
If you call Paul and talk to him tell him Leon from Ithaca sent you as you need a snowblower.
I think you have suffered enough with this.
   / Pictures of your snow weapons #5,516
There are no Pronovost dealers close to me here in the Northern Rockies. And they are at least $2k-$3k more expensive. I'll give them a chance to fix it.
   / Pictures of your snow weapons #5,517
I love my M K Martin Meteor Rear Pull Snowblower. It runs as smooth as silk. They will get it right.
   / Pictures of your snow weapons #5,518
In the video, the noise is in sync with the chain that keeps the plastic shielding from spinning wiggling.
Hope it's that simple.
   / Pictures of your snow weapons #5,520
That is good to hear TYMNorsky,
Did they reinforce the rear plate weldment by welding gussets to the back of it???
I would love to hear what they did to it.
Dewalt D28499 7/9" Angle Grinder/Sander (A59076)
Dewalt D28499 7/9"...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2246 (A58376)
2246 (A58376)
72" General Purpose Skid Steer Bucket, S/N 103581 (A59076)
72" General...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2017 Ram 5500 Service Truck, VIN # 3C7WRMBJ9HG711025 (A57453)
2017 Ram 5500...
