Pine needle rake(everything attachments)?
   / Pine needle rake(everything attachments)? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Has anyone bought the pine needle 3 pt. rake(5 ft. yellow one) from everything attachments?If so how do you like it?I am thinking about purchasing the 5 ft. model in the near future.Thanks for any information.coobie
Somebody here has one and I am sure they will be along to tell you about it? IIRC they liked it.
Thanks glen.I want one for dethatching the lawn and leaf clean up.coobie
   / Pine needle rake(everything attachments)? #5
coobie,
I have the older Leinbach model with welded tines, I like the idea of replaceable tines and will purchase one of these when I need a new one. Heres some pics of my 6' rake and x749, does a good job imo.
To make a more agressive pass I hang two 42# weights around the top link post for mild dethatching.
coobie,
Great pics,you sold me now.I want to use the rake behind my JD X748 for spring dethatching and fall clean up for some of my leaves and pine needles.
   / Pine needle rake(everything attachments)? #7
coobie,
The PSR doea a great job with the needles but a fair job with small leaves. Lots of small leaves will pass through it. The tines are on 2" spacings, so as you can imagine lots of small leaves will be left behind. After raking an area with leaves and loosening them up I often use my Stilhl backpack blower to clear the leaves out.
coobie,
Steve,thanks for the info and pics.My lovely wife ordered the 5 ft. rake today from everything attachments.Early Xmas gift.LOL,coobie.
   / Pine needle rake(everything attachments)? #9
coobie,
I have have the same issue, does NOT work well for leaves. I also use a Stihl backpack for cleanup. I think the rake is to aggressive for dethatching use.
I am going to sell mine on Craigslist in the spring I think.
   / Pine needle rake(everything attachments)? #10
About the rake being too aggresive for dethatching I found the opposite to be true, but that is likely because the 3ph weight on my garden tractor is very light compared to the hitch on a larger tractor. You can shorten the top link to change the angle of the tines too.
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
2010 John Deere Gator UTV (A49461)
2010 John Deere...
