Joshmcmillan
- Joined
- May 12, 2022
- Messages
- 2
- Tractor
- New Holland TL100, TS100 x2, T5050, Fiat 580DT, 540
Hello! Appreciate any assistance or ideas.
We have a New Holland Tl100 with the 2 speed power shift and shuttle.
Recently it sat for a couple of weeks, and jump started fine for use. It started under its own power and was used later the same day.
A few days later, battery was flat again so I replaced it. Now the tractor won’t move.
It starts fine, all other hydraulics work. No fault codes or lights on dash. Does not display the rabbit/turtle light as it would usually. Dealership came out and there computer wouldn’t plug into it so they left.
I have checked wiring to solenoids, checked resistance on clutch sensor, shuttle lever works etc…..
Is there anything else I can try?? Once I had to calibrate the transmission on our TS100 after changing battery - could this just need that if I called a dealership requiring 8 hours travel that has the right tooling? Or if it needed that should it be displaying the fault light on the dash?
