Plywood for concrete forms
   / Plywood for concrete forms #31
I am not a chemist like everyone else on this spiraling out of control thread, but I put a roof on a storm shelter located in my garage. I used 3/4 treated plywood and after a little bracing I poured an 8" thick x 8'x8' slab as the roof. There was no way to get the plywood out after the fact. It has been 3 years and still looks like new. I did throw some screws into the wood to hold it to the concrete just in case it would sag in the center.
   / Plywood for concrete forms #33
It takes a lot of bracing to form a wall using plywood.
   / Plywood for concrete forms #35
After building a small number of walls using 20 sheets plywood and having to buy tons of 2x4s I found out that every piece of wood got sucked into the system anyway. A lot got reused for other concrete walls, a lot got used for shelving in the garage and barn. It all got used up someplace else so it was not all money down the drain.
   / Plywood for concrete forms #36
Yep it can be used again definitely. Also, other side of the formed wall looks the same. With lots of form ties to hold them together. Just wanted to offer OP an idea what is involved. Concrete will bulge or even knock down the form if given a chance. Better safe than sorry.
   / Plywood for concrete forms #37
Or cross ties between the walls, Forms for my patio retaining wall (6!x4'x24' consisted of 2x4 lengthwise top and bottom, a few vertical 2x4 and a lot of 'snap off' cross ties.
   / Plywood for concrete forms #38
We have a product called Formply, it is a black coated plywood designed for concrete formwork, I'm sure you would have the same thing but probably with a different name.
Have used this for various tasks not relating to concrete and the last one was for a new ramp on a horse float.
   / Plywood for concrete forms #39
Yes to snap ties. The photo I put up shows lots of snap ties connecting the walers.
   / Plywood for concrete forms #40
I think you just made Snobdds point. :)
SnobDds is completely wrong. Rock crawler is correct, the cement hydrates in the concrete while water is incorporated in the new compound. Water does not evaporate, except the excess which is not needed in the chemical reaction
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
40' CONTAINER (A52706)
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
