Pre-Oiler?
   / Pre-Oiler? #11
I agree, a good idea but not needed. If you are worried about it, run a full synthetic diesel oil, flows much better during start up.
   / Pre-Oiler? #12
   / Pre-Oiler? #14
I had a pre-lube pump on a 86 F250 with an aftermarket turbo. I installed the pre-lube pump after adding the turbo. It was very handy for me as the truck would sit for months (sometimes 6 months at a time) without use. Using the pre-lube allowed sufficient oil to lube the turbo before start up.
The pre-lube pump saved my truck engine when the engine oil pump pickup tube cracked and sucked air in. I was able to switch the pre-libe pump on to get me home safely (long story). So for me, it proved to be invaluable and saved me a bunch of money.
On the tractor, I don't think it would be necessary - I don't have one on my tractor and don't see the need.
   / Pre-Oiler? #16
Once you've broken the engine in by using conventional oil for a few times,and at least 100hrs,consider switching to Schaeffer's x9000, 5w40 with 15- 20 percent bestline HD diesel engine treatment..its the best lubrication I've ever used and my oil samples come back with the lowest wear metals I've ever had.
   / Pre-Oiler? #17
Not using a block heater and synthetic oil in the winter will cause more wear than what a pre-oiler will save.
Good point, although I think switching to a full synthetic year round is even better. That's what I plan to when I change the oil my L4330. I don't even think I have any non-syn oil anymore, I've changed everything over to synthetic.
I use Shell Rotella T-6 5W-40 for everything except my Stihl/Husky chainsaws.
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
