problem removing NH flail mower bearings (roller)
   / problem removing NH flail mower bearings (roller) #1
sreavis
triad area, north carolina
kubota, MF, Ford
I bought a New Holland 917H, the bearings on the roller (rides on the ground) need replacing (1 had failed completely). They are in the height adjustment housing. One is intact within the housing) the other had failed and just has the inner and outer race left. No luck removing the housing with 3 jaw puller and heat. Any insight would be greatly appreciated. I'm hooked on flail mowers since I bought my 6' Caroni flail and got a great deal on this 90" NH.
Scott in NC
   / problem removing NH flail mower bearings (roller) #2
Cut the race with a dremel and use a blunt chisel to split it. Eye protection, gloves and long sleeves recommended.
   / problem removing NH flail mower bearings (roller) #3
You have two E rings that are holding the roller in place if you have the sealed end cap type of bearing and roller holder.
   / problem removing NH flail mower bearings (roller) #4
Scott in NC
We always remove the stuck bearing housing in this way. Designer should think about if easy to maintain it.
I will take a few pictures and post so you can the issue. Many thanks for taking the time to assist. Scott
   / problem removing NH flail mower bearings (roller) #6
Heating the housing often works. Both the housing and the race will expand but the housing expands more. You can try cooling the race but that can be difficult.
I've used the dremel and chisel trick too. Cutoff wheel is the best if you can get it in there. The race will be hard so regular HSS bits won't do it.
   / problem removing NH flail mower bearings (roller) #7
Scott, for the race (item 15) stuck in the bearing housing (item 18) see pic, if you have a welder weld three 1 inch beads on the inside of the race and let it cool. The welds will shrink the race and it should come out of the housing (item 18) with no real effort.
   / problem removing NH flail mower bearings (roller) #8
I would like to know if part number 23 which is the E ring was removed???
Here are a few pics. The bearing holder is also the height adjustment for the roller. There is a snap ring that holds the bearing assembly. Little room behind the assembly, I ground down the feet of my 3 legged puller to fit behind the assembly and heated the stuck inner bearing with a torch but it would not budge. Difficult to get good assess with the torch. Hard to get a split bearing puller behind it because of the height adjustment plate. No room for a die grinder, cutting the inner bearing is not an option without risking damaging the snap ring groove. I wonder how the dealer mechanics removed this assembly to replace the bearings?IMG_0742.jpgIMG_0743.jpgIMG_0742.jpg
Assembly is the bearing holder/height adjustment, then the bearing then the snap ring unless I being a big dummy, which is possible.
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2007 MACK CV713 ROLL OFF TRUCK (A58017)
2007 MACK CV713...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
