PROS CONS MID MOUNT VS FRONT MOUNT? ZERO TURN
   / PROS CONS MID MOUNT VS FRONT MOUNT? ZERO TURN #1
sperry
Bronze Member
Southern, VT
TYM T300 HST, Kubota B7610HST, XMark Lazer Z 60"
INFO NEEDED
Wondering if someone could give some advice about front mounted mower deck vs mid mount. I have about 12 acres of mowing to do with lots of obstacles and hill. I'm wondering if my tractor with 3pt mower is the right implement for the job, given it cant do zero turns or get close to trees. I'm looking at the Exmark Front Runner and the Lazer XS. I also want to look at the Scag products.
___________________________________________________________________
TYM300HST KUBOTA B8200
   / PROS CONS MID MOUNT VS FRONT MOUNT? ZERO TURN #2
Mid mounts can't get under trees as well as a front mount can. You might also want to look at a Gravely Rapid XDZ for a front mount unit. They come in both 60" and 72" cuts. With the Rapid, you might give up your mowing with the 3-pt unit. :)
   / PROS CONS MID MOUNT VS FRONT MOUNT? ZERO TURN #3
front mount - can reach under trees and over/up banks
mid mount - easier to follow sharp curves and zero turn
I've had a Scag Tiger for a few years now, it replaced a Steiner (4wd with front mount deck). I like the Scag better for pretty well everything: hills, trees, flat ground, you name it.
   / PROS CONS MID MOUNT VS FRONT MOUNT? ZERO TURN #4
Mid Z has better traction because of weight distribution. Also more compact for better manuverability in tight places. A front mount Z can sometimes take pto attachmnets. You have to figure what you want to do with it and get the appropriate one.
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
2025 40 ft. High Cube Shipping Container (A50860)
2025 40 ft. High...
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
2025 K2223 UNUSED Double Garage Metal Shed (A50860)
2025 K2223 UNUSED...
2018 Toro Sand Pro Bunker Rake with Edger/Broom (A49461)
2018 Toro Sand Pro...
UNUSED Garden Hose 164 ft. (A50860)
UNUSED Garden Hose...
