PT422 First Engine Oil Change
   / PT422 First Engine Oil Change #1
duane
Toro 266H and PT422
The Robin Engine manual says to change the first oil at 20 hours. I'm used to changing it at less hours on a new engine. What did you guys do?
Duane
   / PT422 First Engine Oil Change #2
What do they recommend after the first change?
PJ
   / PT422 First Engine Oil Change #3
every machine that comes into our shop we change after 5 hours over to synthetic oil, especially the one that always or most the time run at full trottle i.e. mowers etc.
   / PT422 First Engine Oil Change #4
Duane,
What part of Maine are you from? I am looking to purchase a 422 possibly next week and I am in Saco.
   / PT422 First Engine Oil Change #5
Ah, so someone does use synthetic oil in the engine! I was thinking about that. Should significantly prolong the engine life. What weight should I use in my Briggs 18HP V-twin?
Dave
   / PT422 First Engine Oil Change #6
we use whatever is recommended by the manufacturer as far as weight goes. my exmark has the identical eng as the pt and they authorize 100 hours per oil change
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
2008 FORD F-450 (A50854)
2008 FORD F-450...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
1041 (A50459)
1041 (A50459)
