Jaylegger
Platinum Member
- Joined
- Oct 4, 2009
- Messages
- 713
- Tractor
- Massey Ferguson GC2600L
Safety wise, it makes no difference if th plastic housing spins with the shaft or not as long as it will stop spinning if something gets into it, which is almost an impossibility it it is all complete. IF something were to touch it and get wrapped up, then the plastic would then free wheel and allow you to pull back and free yourself. Chains all over are not necessary for it to function. If you can turn it by hand on the shaft without turning the PTO shaft itself then it is working correctly and doesnt need to be chained up. I dont believe the first guards even had chains and they were added by the safety police because of folk like those here that think it is unsafe because it spins with the shaft. It is a floating guard not an immovable guard.
I havent' tested but am wondering how the free wheeling action might be affected if something gets wrapped around it and then something heavy, similar to a human body, falls against the side of it. Any takers?
Despite that how would one know the cover can still free wheel and not jammed or stuck due to debris if it's considered "normal" to see it spinning. Holding the cover in position with a chain is the only on-going way to know the cover is functioning as it was designed. The purpose of the relatively thin chain is to establish a level of safety, if the forces are strong enough to break the chain that is a marker that either an acute occurrence has rendered the cover unsafe or that the slow degradation or debris buildup of the unit has now reached a level of concern which needs to be addressed while at the same time potentially still maintaining a level of safety. Unchecked, both may lead to a level of binding which and cause serious injury. If the chain is breaking or the ear is ripping off that might be red flag that the cover might require repair or cleaning and might not be as effective in preventing injury. In an industrial setting that piece of equipment would be taken out of service immediately until repaired.
Allowing the cover to spin with the shaft is a highly unsafe practice and I highly encourage those reading this thread not the follow that advise. From a safety standpoint, removing the chain that came with the cover is not much different than removing your homes electrical panel fuses and hard-wiring everything.
