Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
It varies from machine to machine, depending on your pto shaft / stub.. etc. Some 2-speed pto units with swapable shafts ar a little more involved with the gearing.. but then some are pull out/slap back in.
( on an 8n you can park nose down in a ditch, pull 4 bolts and slid ethe whole assy out, pay 100$ and slide a new assy in, and put the bolts back in and never loose a drop of oil.. take you about 5 minutes if you are lucky!.. don't count on your 3910 being that easy.. but should be easier than a 2-speed unit if yours isn't. )
By the way.. RickB is -way- more knowledgeable with the new machines ( read: 1965 and newer ) than I am. Most of my daily hands on work is wit the N and hundred series stuff. Rick can probably rattle off the seal number and tell you the in/out from memory on a newer machine like that.
soundguy
soundguy
