Pump - Trash or Semi-Trash
   / Pump - Trash or Semi-Trash #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
   / Pump - Trash or Semi-Trash #2
As far as I know, the trash pumps will pass a larger solid than a semi trash. The ability to pass such objects is traded off for effective pumping - a semi trash should have slightly higher discharge pressure and rate than the same size trash pump all else being equal. Either pump should have seals capable of service in dirty or silty water - unlike a common water pump.
High dollar trash and semi trash pumps may also have abrasion resistant lining on the inside of the housing rather than bare cast iron.
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
Non running toro mower (A48082)
Non running toro...
1998 Ford F800 Water truck (A49461)
1998 Ford F800...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
