Snow Pushing Snow ith BX24
   / Pushing Snow ith BX24 #11
Those pictures should tell the tale on snow removal. Nothing like seeing the real thing!:D
   / Pushing Snow ith BX24 #12
I've done my driveway for years this way. The only thing I'll mention is to always keep your 2 rear tires on the driveway. If you don't go perpendicular to the driveway you could get stuck. Just a precaution to take.
I bought a rmsb last week. I can't take being out working on the driveway for 4 hours at a time.
   / Pushing Snow ith BX24 #13
Here is my "slush pusher" - we haven't got too much snow in MA the past few years - so this works very well - bucket still fills, driveway protected, etc
Rev 2 will put an angle on it though...original design flaw :)
   / Pushing Snow ith BX24 #14
Dog Lover said:
Has anyone any thoughts on just how well the BX24 does just pushing the snow with the FEL? I am hoping it will do a good job and not need a blade on rear....I was planning on just pushing and letting the FEL load up and keep pushing rather than dumping it. When it gets high enough at the end of push, just load it in FEL and dump further back in the woods or off drive. I am sure some of you have already tried this...did it work well?:confused:
It will work fine, I used the FEL all winter this past year. Just be careful not to dig into the asphalt. It works especially well when you have ice, like we did this past year, it was easily able to dig up chunks and clean the drive.
   / Pushing Snow ith BX24 #15
Without a doubt, put SOMETHING on the wear edge of the bucket. I pushed snow on some concrete driveways and I noticed a significant amount of wear. Not too much to cause a problem, but more than enough to know that I did not want to have this be my permanent solution
   / Pushing Snow ith BX24 #16
I don't know about pushing snow away but my bx 23 has done an excelent job of keeping it away .
Since I got it in Sept of 2004 we've only had about 3 snows and they were only about an inch deep.
   / Pushing Snow ith BX24 #17
I do a 100 foot gravel driveway with a FEL on a BX. It works real well but I have found it's best to let a layer of snow get packed down on top of the gravel before I start pushing the snow. That way you don't get mouthfulls of gravel dumped on your lawn or where ever. I just run back and forth on the first few drops of snow to pack it down.
   / Pushing Snow ith BX24 #18
ihookem said:
So good luck and don't think the bx is any less of a "pusher" than the 7510. I think the bx might better cause it's a few horse more and the smaller tires will give it more torque. Later, Steve.
I have had a bx24 and a 7510. The 7510 is a much better pusher than the BX. The one thing to keep in mind is that the horsepower ratings between the two doesnt mean squat. The engine in the 7510 is more powerful than any of the BX engines. The B7510 uses a considerably larger displacement engine than the BX. The BX engines are just spun faster in order to acheive a high horsepower rating. When it comes to pushing, torque is far more important than horsepower. I calculated the torque difference between the 2, this is what i came up with.
Formula to calculate torque from horsepower- Torque=horsepower*5252/rpm
BX24=23hp@3200rpm
B7510=21hp@2600rpm
BX24- 23(hp)x5252/3200=37.74lb/ft of torque
B7510- 21(hp)x5252/2600=42.42lb/ft of torque
OP- Sorry for the off topic, to answer your question, when i had my BX it would push snow very well. you might want to consider some added weight though.
   / Pushing Snow ith BX24 #19
Scrounger said:
I also have a 2" thick piece of composite plastic under my bucket to keep the driveway from getting all nicked up. I bolted it to the leading edge. A 2x8 works too but it has to be replaced very quickly if you really abuse it. I did that for a season before I bought the plastic piece. Its actually a plastic 8' plow blade that I cut in half and bolted flat.
Scrounger:
Would it be possible to post some pix of your setup? I'd like to set something up for my 3030 similar to what you mention.
Thanks.....
Swmpbgy1
Grecer Food Trailer (A55973)
Grecer Food...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
PALLET OF CARBURETORS & PARTS WASHER (A58374)
PALLET OF...
NEW Wolverine Skid Steer Pallet  Fork Hydraulic Adjustable (A59000)
NEW Wolverine Skid...
