Question about hydraulics on a 5M
   / Question about hydraulics on a 5M
OK, the tractor is home.
Replaced hydraulic pump and manifold. (plus oil, several gaskets, one hydraulic line, etc)
Total repair bill was over $2600. Still haven't heard from the JD factory rep as to how much of it I'll have to pay.
   / Question about hydraulics on a 5M #32
That's good you finally have the tractor back. Hope now they take care of you on the repair price.
Yep, good to have her home.
Will just have to wait and see on the bill.
   / Question about hydraulics on a 5M #34
Hey Bigfoot,
Glad you got your machine back; hope they take care of you too. So what caused the manifold and pump to go bad? My 09 M has about the same hours as yours, but no problems yet just work done and enjoyment doing it.
Regards,
Tom
. . . So what caused the manifold and pump to go bad? My 09 M has about the same hours as yours, but no problems yet just work done and enjoyment doing it.
Tom, From what I can understand, the manifold on some of these tractors is bad. Just a bad casting. The manifold is cast aluminum. All it takes is a pin-hole. The pump is mounted up high on the transmission case, so it's above the fluid level. If the casting is bad, the fluid leaks from the pump and back into the transmission. Then, when you start it back up, the pump is running dry. As the pump begins to wear, it takes longer each time for it to regain its prime. The longer it runs dry, the more it wears. Not good, to say the least.
Again, from what I've learned, if you haven't had a problem yet, chances are you won't. Realize that this happens to just a very few of these tractors, literally a small fraction. The service manager said that mine was the ONLY 5M that he knows of with this problem. I didn't realize that I had trouble until it had almost 400 hours on it, and it was just out of warranty (of course). Of the few that have responded with similar problems, most seem to occur much sooner.
The folks on this forum are great. Thanks to AKfish and jd110, I was able to give my service manager the John Deere service solution number. (like an automotive TSB) It made his job a lot easier, and probably encouraged the JD factory rep to go ahead and authorize the repair.
   / Question about hydraulics on a 5M #36
Thanks very much for that excellent explanation Bigfoot, much appreciated. And you are so right about Akfish and JD110; they are two of the many knowledgeable and supportive guys here that are always ready to help.
Thanks again guys.
Regards,
Tom
OK,
Just thought I'd let everyone know.
I've had opportunity, over the last couple weeks, to work the tractor. Put about 25 hours on it, since the repair. Everything seems to be perfect. Looks like it's finally fixed. What a relief.
And even better, it's been over 2 months, and I still haven't received a bill. (at least, not yet) I'm hoping that JD just took care of it completely. And, if they don't say anything, I surely won't. :D
Thanks again to all those who helped and offered advice. It's been just another reminder of how great this site can be. :thumbsup:
Talked to the dealer yesterday. John Deere fully covered the repair. It's official, I don't owe anything. It only cost me the time and fuel to carry it in and pick it up.
BTW, I really like my JD dealership: E. S. Voelker
   / Question about hydraulics on a 5M #39
Good to hear they took care of you on the repair and the tractor is running well.
Thanks.
PALLET TOTE OF JARS & MISC (A58374)
PALLET TOTE OF...
2017 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2017 Kenworth T800...
2013 Ford F-750 Truck, VIN # 3FRXF7FL2DV789551 (A57453)
2013 Ford F-750...
Kubota L4701 (A53317)
2007 INTERNATIONAL 9200I (A58214)
2007 INTERNATIONAL...
2017 Snorkel S4732 Scissor Lift (A57453)
2017 Snorkel S4732...
