Question about return filters
   / Question about return filters #1
doc70
middle Tn.
Kubota L3301
Just got my ht-18 on Tuesday and before I put too many hours on it I want to add a return filter and change out the mystery oil that came with it. What pressure relief do I get with the filter housing? and what micron filter?
   / Question about return filters #2
If return line filter they typically have a built-in by pass valve typically in the 25 - 30 PSI range.
Micron kind of depends on components and pressures but common size is 10 micron. Size this filter large enough for cool weather and cylinder ratios so probably 25 - 30% larger than pump flows.
I would also get some form of plugged filter indicator, mechanical pop up if filter is visible or electric and put light on console.
Thanks for the reply, Generally I was seeing 5psi housings with 25 micron filters and 25psi with 10 micron. so, 25psi bypass with 10 micron and a gauge.
   / Question about return filters #4
I put a temperature sender on one of the ports on my return housing so I can keep an eye on hydraulic oil temperature while inside the cab.
That sounds like a much better idea than just a gauge at the block. Already a lot of work to come to a machine that hasn't seen it's first full Hr. I am also going to flush the cooling system and change the oil asap.
2015 FORD F750 BOX TRUCK (A43003)
2015 FORD F750 BOX...
2003 MACK RD688S DAY CAB TRI-AXLE (A45333)
2003 MACK RD688S...
2022 Suzuki King Quad 750 non-Runner (A42744)
2022 Suzuki King...
1981 Miller 40' Citrus Trailer (A44500)
1981 Miller 40'...
2017 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A42742)
2017 JCB 930...
2004 MACK CH613 (A45046)
2004 MACK CH613...
