Snow Attachments Question on possible installation of a snow plow.
   / Question on possible installation of a snow plow. #11
my snowplow (truck mount) was 250 bux. i cannibalized it to mount on my 4x4 forklift. unstoppable.
   / Question on possible installation of a snow plow. #12
Does your truck have a plow on it now? If not a used setup will cost some money ($2000). A cheap, non roadworthy plow truck with plow will run the same price.
But to limit the amount of junk in your yard, a used compact tractor will do all you need. It would probably be your best and most economical solution.
   / Question on possible installation of a snow plow. #13
I would not drive a 2wd truck in snow never mind try to plow with one. As noted plows are not low cost and about 40% of the cost is on the truck side, frame plus electronics. As suggested look for an older used 4wd truck with a plow already attached or look for someone else to plow. The latter is the better option as you will need a 3/4 ton 4wd truck and sturdy plow to handle what I assume is a gravel 1/3 mile drive. A light duty "half ton plow" would get beat to crap on a long gravel drive.
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2014 FORD F-350 UTILITY BED (A58214)
2014 FORD F-350...
LOT OF ANGLE IRON VARIOUS SIZES (A58374)
LOT OF ANGLE IRON...
4 WHEEL WAGON GEAR (A52708)
4 WHEEL WAGON GEAR...
2020 Husqvarna YTH22V46 46in Riding Mower (A56859)
2020 Husqvarna...
