R1 or R4 suggestions for me
   / R1 or R4 suggestions for me
What kind of tractor?
Can wheel spacers be used?
Adjustments on rear axel?
DGS
It is a Kioti DK45S
I don't know if spacers can or should be used. Does this weaken anything by using spacers?
I don't know if there are adjustment on the rear axle. I will ask the dealer later today.
   / R1 or R4 suggestions for me #22
Most tractors have adjustable rear wheels. The rim is bolted to the center section. The center section is dished. By mounting the rim to the center dish in vs dish out you change the distance between the wheels. The place where the rim mounts is also off centerline, so you can change there too. That gives 4 distinct widths.
If the standard rim/center does not allow for adjustment, DON'T BUY IT. Tell the dealer to either provide adjustable wheels or buy them from the tire store yourself.
A lot of the "can't be done" the sales people give out just means we don't want to as it might bit into our profit.
jb
   / R1 or R4 suggestions for me #23
Are R4 rims adjustable? My R1s are, of course, but I don't know about R4s. CrazyQ, on my Kubota the rims are just as John outlined above, and it can get a little hard to visualize and in some cases you have to remove wheel center, flip it and bolt it back to a different set of tabs on the rim. This really isn't difficult, but, the way mine came from the dealer, you could just swap sides with the whole tire/wheel/rim assembly for a wider stance. This is very very easy, just move the right one to the left, keeping the 'arrows' in the tread pattern facing forward. This simple change could move the high point of the tire (the center) out from under the fender altogehter.
DGS
jb
I understand the dishing for width adjustment but do I understand correctly that by mounting the rim off the centerline it will virtually mount the wheel further back (laterally) toward the rear. The area of the tire that is close the the fender is nearer the front of the tire versus the top so it seams this adjustment would allow for clearance.
   / R1 or R4 suggestions for me #25
The rim has loops that are welded off center (towards an edge), when you bolt the center to the rim, you can then move the tire further out from or closer in.
N80 - my R4's are on adjustable rims. All three tractors.
jb
   / R1 or R4 suggestions for me #26
R-4s are good all around tires, but IMO, the only thing worse in the mud would be turfs. I speak from experience.
Looks like a mess. Were you able to push yourself out with the bucket? This is one of my fears for an area I want to clear to make a field...there are some booger holes like the one you are "parked" in.
   / R1 or R4 suggestions for me #28
That time I was able to push it out with the bucket, a few times though, I could not. The biggest drawback to the R-4s in the thick mud is that when the front end goes in to the axle, often the back does not have the traction to pull the front out, even in a couple inches of mud. If you do not stop and re evaluate things right away, you will bury it every time. My rears are loaded with calcium and I have a 500 or so pound box scraper on it, and still lack rear mud traction due to the tread clogging.
   / R1 or R4 suggestions for me #29
A better rear weight in that situation is a forward rotation rototiller. It acts just like a paddle wheel and can give you a big boost out of a booger hole. Or just push you in even farther. I've done both!
jb
   / R1 or R4 suggestions for me #30
I have recently bought a complete set of 4 R-1's, I am now looking for a good used set of front wheels. In hindsight, I should have just bought a good used hydraulic winch, it would have been way cheaper than another set of tires, and close to 100% effective, as long as I have a tree close by to hook onto, and I have lots of trees.
AEREATOR (A58214)
AEREATOR (A58214)
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
2- 5TH WHEEL PLATES (A58216)
2- 5TH WHEEL...
2022 ALLMAND LIGHT TOWER (A58216)
2022 ALLMAND LIGHT...
Terms and Conditions (A55272)
Terms and...
