>>>>R2500 GIZMO ON COWL ????
   / >>>>R2500 GIZMO ON COWL ???? #1
BearKiller
Located on the "instrument panel", cowl, whatever it's called, on the upper portion, right-hand side, is an about one-inch round dome-shaped metal gizmo with a series of holes, much like a salt-shaker lid.
What is this gizmo ??
Also, just below and a touch farther to the right is a chrome-ringed black push-button; I am assuming this is factory original; what is this button supposed to be ??
Thanks.:cool:
Glow Plug indicator.
Is it supposed to light up or something ?? or maybe be a buzzer ??
I haven't noticed it do anything.
I am pretty sure the glow-plugs work, as the longer I hold them ON, the quicker/easier it starts.
Thanks.:cool:
   / >>>>R2500 GIZMO ON COWL ???? #4
There is a small coiled wire in there that will glow red hot if you hold the glow plugs on long enough.
Hmmmmm........, I will have to check that out; I would have figured it to be a buzzer.
Of course, the wires under there may be hanging loose and it not even be connected, I will check that first.
Thanks so very much for the information.:)
   / >>>>R2500 GIZMO ON COWL ???? #6
the salt shaker thing is most definitely a glow plug indicator.when it is red means the glow plugs are ready.if you look through the holes while heating the plugs you will c the filament glow.
Thanks.
I have been watching for the glowing filament but ain't seen any action yet.
The glow-plugs themselves must work, though, as the longer I hold them on, the quicker she starts.:)
It was getting dark and I needed to move the tractor.
I held the plugs on for a few seconds, maybe ten, while looking down into that salt-shaker gizmo.
In daylight, I hadn't seen any activity whatsoever, but this evening, at almost dark, I could see the little coil glowing red-hot.
If that salt-shaker wasn't in the way, it would make a dandy cigar lighter.:D
   / >>>>R2500 GIZMO ON COWL ???? #9
ah haha yea right.
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
