Ram 1500 EcoDiesel
   / Ram 1500 EcoDiesel
2500. Going to put air bags in the rear to help with towing.
   / Ram 1500 EcoDiesel #72
Not sure if you are a member of, or visit, the forum RAM 1500 Diesel Forum, but there is a lot of air bag experience documented there. Seems the most popular are Timber Grove and TLC. I'm no expert on the subject, but have read many of those threads, and I believe both of those companies offer setups with and without compressors. Timbrens also seem to be a popular option. Timbrens are bump stops, and a cheaper option to air bags. that seem to help with sagging and many members of that forum use them and like them. Seems like you tow a lot, so air bags are probably the better option and well worth the extra money for your situation. Just a few options for you to consider as you research.
I hit 6,700 miles on my Ecodiesel yesterday on a trip to Morgantown and back. Lifetime MPG is just over 23 according to my fuelly app. The more I drive this truck, the more I like it!
I'm not a member at the 1500 diesel forum but I've been reading it a lot.
I'm thinking about going with the air lift 1000. I don't need a lot of lift, just maybe 2 inches. I'm probably not going to install on board air. I'm gonna put the 1000 series bags in for minimal cost and start with 5 psig.
One thing that worries me is on some of the bags you remove the factory springs. I'm not real clear on it. What happens if one of those bags fails??
   / Ram 1500 EcoDiesel #74
You probably need a weight distribution hitch.
   / Ram 1500 EcoDiesel #75
That's a good question and one I don't know the answer to. I'd have to hear a pretty good argument for getting bags that require removing the factory springs. I plan to go with a 100% bolt on option when I'm ready.
I also don't plan on getting on board air, as I don't want to give up space to a compressor and tank for something I will not use often.
Good luck and keep us posted on what you end up with.
   / Ram 1500 EcoDiesel #76
The air bags just support and supplement the factory springs and usually replace the bump stops.
   / Ram 1500 EcoDiesel #77
I had these on my 2014 Ram. They work very very well.
When you install them, the spring has to be in full droop, no weight on the tire at all. I used a large wooden spoon to work the bag into the spring. I would wait until some warm weather to do it, or bring it inside a heated garage. The bags are pretty stiff when they are cold.
   / Ram 1500 EcoDiesel #78
That's the answer. Per RAM, WDH for trailers over 5000lbs. That would eliminate the rear sag and give you better handling up front too.
Since I know nothing of WDH can someone explain what the difference is and recommend a brand?
70-80 degrees almost all winter here in S tx. :thumbsup:
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
2007 Honda CR-V SUV (A56859)
2007 Honda CR-V...
Lone Star dump trailer (A55973)
Lone Star dump...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
