Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #711
Don't know why I'm getting so many double posts lately.
   / Ram1500 EcoDiesel V6 revealed! #712
Why can't we have a n/a gas engine, turbo gas, and diesel option with everyone b!+$ing. Truck threads on this site aren't very enjoyable anymore, all the gas fans bash any diesel option and the diesel fans bash the gas engines. Everyone just needs to relax, if I want a gas or Diesel engine that gets 10 or 50 mpg and might cost 100k it's my money why does every care so much.
   / Ram1500 EcoDiesel V6 revealed! #713
Because, well, somebody's gotta be right! Or better than other's... or both.
   / Ram1500 EcoDiesel V6 revealed! #714
You can spin it any way you want but the new Dodge payload capacities are unacceptable. It will catch on like wildfire at some point unless they correct the situation before it does. My guess is they will address it before any major damage is done. I just wouldn't want to be the sucker that owns ones of these "prefix" trucks.
I drive an F250 and don't need the full capacity most of the time. But 490 lbs? Unbelievable! That is probably less than ANY vehicle minus the sub-compacts.
   / Ram1500 EcoDiesel V6 revealed! #715
You can spin it any way you want but the new Dodge payload capacities are unacceptable. It will catch on like wildfire at some point unless they correct the situation before it does. My guess is they will address it before any major damage is done. I just wouldn't want to be the sucker that owns ones of these "prefix" trucks. I drive an F250 and don't need the full capacity most of the time. But 490 lbs? Unbelievable! That is probably less than ANY vehicle minus the sub-compacts.
Before I condemn the new Eco diesel ram I will have to see the door sticker for myself. I'm not in the market for one but out of curiosity I will probably go look at there capacities for myself when they hit the lots. Most of the magazines and YouTube reviewers know less about trucks than my dog.
   / Ram1500 EcoDiesel V6 revealed! #716
Review: 2014 Ram 1500 Eco Diesel (With Video) | The Truth About Cars
Towing & Payload
The 2014 Silverado痴 1,875 to 2,100 pound payload easily bests the Ram痴 1,340-1,620 pound range and even the F-150′s 1,510-2,090 is superior depending on how you align the trim level comparisons. (Ford still offers a 滴eavy Duty package on the F-150 which gives it a stronger frame comparable to the F-250 but Ram and GM have killed similar packages on their models.) Likewise the Ram Eco Diesel痴 9,200lb tow rating pales in comparison with the Silverado痴 12,000lb towing rating. Until you actually tow or haul that is.
Can't verify any of the information.:D
   / Ram1500 EcoDiesel V6 revealed! #717
I agree with most of this. But the RAM ED tested does have 490 lb payload. The actual truck window sticker was posted, and all the trucks were weighed/scaled. I'm sure there are stripped down versions with the ED that can get the payload up closer to a half ton. If someone wants a commuter car\truck that they can haul light loads occasionally, this Ram ED would be a good choice.
   / Ram1500 EcoDiesel V6 revealed! #718
I've never seen "Ram" and "ED" in the same sentence before.
   / Ram1500 EcoDiesel V6 revealed! #719
Egon, That article seems to agree with what I've been saying here:
Quote from review:
"It doesn稚 hurt that the Ram is slightly cheaper than the Ford or Chevy when comparably equipped. Toss in the first small diesel, the only 8-speed automatic, a load leveling air suspension system and you have quite simply the best tow vehicle in the half-ton segment."
   / Ram1500 EcoDiesel V6 revealed! #720
"If you experience transporting 490 lbs for more than 4 hours, please contact your mechanic.":eek:
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2002 Wacker RD11A Tandem Smooth Drum Roller (A55851)
2002 Wacker RD11A...
Electric Mobility Scooter (A51694)
Electric Mobility...
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
