rear balde for 50hp tractor
   / rear balde for 50hp tractor #11
That is the same thing that I do, but I still want a little more height. I feel that the boom should be parallel to the ground when working.
Just my opinion
Brian, are you saying when working your blade, the boom is not parallel to the ground?
You should be able to lower the drag links and lengthen or shorten the top link until the boom is parallel to the ground. A combination of adjustments I would think?
   / rear balde for 50hp tractor #12
I have a light one on my NH 40hp tractor. I just bent it today. Caught the end of it on something in drive I was clearing. I think I will look at the Land Pride models. I am also going to look at their tiller. I would go pretty heavy. Also, make sure it is wider than your back wheels. The one I have now is the same width. When driving forward, I have to drive the tractor off the road in the snow to get the blade where I need it to clear the snow from the edge of the road.
   / rear balde for 50hp tractor #13
Rob, while working, the boom is close to parallel, but when raised up the blade is only 6-8" off the ground. Then shorten the top link and it is ok to transport. Just would like it to be higher without always needing to shorten the top link. As you know, it is a lot of work to pull that lever to retract the hydraulic.:rolleyes:
   / rear balde for 50hp tractor #14
Slippy, be sure to get one that has offset ability. The Land Pride 35 series can offset 12" and the 40 series can offset 30". So if you got either an 84" or a 96" rear blade along with some offset, you would be able to stay on the road better. The 40 series looks to be quite a bit better than the 35 series.
   / rear balde for 50hp tractor #15
Yeap, you are correct Brian. Looking at Land Pride right now. Went to a power show this weekend. Lots of good stuff, and the guys from Land Pride really took the time to talk with me about various issues. They were the same way last year. Going to check out their roto tiller also.
   / rear balde for 50hp tractor #16
Just my opinion
Agreed, that's what I typically shoot for when working with mine as well.
2021 Spartan SRT-XD Zero Turn Mower (A50860)
2021 Spartan...
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2007 Craftsman LT2000 42in Riding Mower (A48082)
2007 Craftsman...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
