Rear blade size on a CK2510?
   / Rear blade size on a CK2510? #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
Getting ready to take delivery on a new ck2510 with R4 tires. Will a 5 ft. Rear blade be big enough?
I will be using it mostly for snow removal and material spreading. What is working for you guys.
   / Rear blade size on a CK2510? #2
Tiogajoe,
I run an old heavy four foot box blade with my CK20S; however, I run a six foot grader blade. I tried a 5 foot, but when I set it to the maximum angle it just did cover the width of the tractor. With the six food I can pull a really nice ditch at full angle. My little tractor pulls it very well, so with the extra power you have I would see no problem. Oh yea, we don't get as much snow as you, but I set my 6 foot blade at like a 30 degree angle last year and moved off the 6 inches of snow with out chains or any other stuff. Just a note, the length doesn't come into play until you change the angles.
   / Rear blade size on a CK2510? #3
   / Rear blade size on a CK2510? #4
6 foot for sure. As stated the 5 foot would not cover the tire width of the tractor when angled.
   / Rear blade size on a CK2510? #5
Diesel Fuel Tank with Pump (A50860)
Diesel Fuel Tank...
Kubota M4700 4WD Tractor (A50860)
Kubota M4700 4WD...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2007 John Deere 7930 4WD Tractor (A50860)
2007 John Deere...
3/4 Electric Drill (A50860)
3/4 Electric Drill...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A50860)
2025 KG43 UNUSED...
