Rear Work Lights on L3940 with a cab
   / Rear Work Lights on L3940 with a cab #1
07 LMM LTZ
Gettysburg PA.
L 3940 HSTC
Has any body added rear work lights on to there cab tractor? I was wondering if all the wirering is there already and all you had to do is install the switch and hook up the lights on the rear.
   / Rear Work Lights on L3940 with a cab #2
I would think all the wiring is there and ready to go, pull the roof, it only takes a half hour.
   / Rear Work Lights on L3940 with a cab #3
Everything is there. You need the switch / light kit. Plug and Play
   / Rear Work Lights on L3940 with a cab #4
I installed Kubota work lights on my L5030.
The cab roof only needs to come off to plug the switch into the available wire harness.
Externally at the rear flasher lights, the bullet connector is enclosed with electrical tape wrapped around the flasher light bracket.
I looked high and low and had to call my wrench to find the Kubot secret location.
   / Rear Work Lights on L3940 with a cab #5
I just installed the Kubota rear light kit #L8333 and it is simple (on my L3540).
1. Bolt on lights to existing bracket.
2. Connect lights to existing connectors (hidden in electrical tape)
3. Pop off existing switch cover in cab - next to other light switches
4. Hook up switch to existing connector - might have to fish for it with finger or hook.
5. Push switch in to hole.
6. Point lights and enjoy.
>>> NO need to pull off cab roof <<<<
