removing a FEL on a Farmpro 2425
   / removing a FEL on a Farmpro 2425 #1
jgriffin9
Farmpro 2425
I have a 2425 and need to remove the FEL to get to the clutch inspection hole. My Clutch is constantly engaged and I need to know how to remove the FEL can someone assist me? I put the center bar down and have been rocking the tractor back and forth to no avail. What should I be doing to get this to separate. I have the 2 pins removed but cannot get it to separate.
ok I found 8 bolts that I had to remove and now the FEL is off. Now to remove the mounting brackets to get to the inspection port. Lets hope this is an adjustment issue. OK got the brackets off nd can look into the inspection panels. No luck looks like the pins in the fork broke and I will have to split the tractor to fix it. Any good suggestions on splitting the tractor. Any shortcuts. It looks like an in-depth ordeal.
UNUSED 30PCS Heavy Duty Hinges (A50860)
UNUSED 30PCS Heavy...
Steel Truck Bed (A50860)
Steel Truck Bed...
2022 Spartan RZ-Pro Zero Turn Mower (A50860)
2022 Spartan...
2016 Hyundai Sonata Sedan (A50860)
2016 Hyundai...
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2024 TOFT 1550 Hydraulic Breaker (A50860)
2024 TOFT 1550...
