Rent a box blade or a rear scrape blade?
Should the noob rent a rear blade or box blade
  • Box blade
    Votes: 25 86.2%
  • Rear Blade
    Votes: 4 13.8%
  • Total voters
    29
  • Poll closed .
   / Rent a box blade or a rear scrape blade? #1
redalrt
I have a small compact tractor (Mitsubishi S373 Beaver III). we plan to spread about 4 cu yds. of topsoil to overseed a bare, flat, farly rocky area.
I'm a total noob with using implements other than a 4' bushhog or the same size finish mower.
I've seen the debate on using a box blade vs. rear blade.
Given the above scenario, which of the two should I rent?
I'm sure that with the box blade, its going to be slightly above the ground with the scarifyers retracted to smooth out the hill of dirt I'll be starting out with.
Sorry if this has been discussed before. Thanks
   / Rent a box blade or a rear scrape blade? #2
I'm debating the same thing myself, so I'll be curious to see what others say. I need to do some driveway leveling and get some ruts out of my yard. I was going to rent one and now I'm leaning toward buying. One reason is I think it would be a good implement to help balance the FEL. It would take up less room than a mower and it would be less likely I'd back into something with it. I'm also thinking the driveway will require future grading. My pickups do tear it up.
   / Rent a box blade or a rear scrape blade? #3
I will have to say, Buy the box blade, you'll have it next time instead of a rental receipt? LOL
Think about it?
Jim
   / Rent a box blade or a rear scrape blade? #4
The rear blade is very practical for grading and smoothing but if you're going to be MOVING dirt, the boxblade will come in very handy. You can also grade and smooth with it, as well as rip. Pushing the boxblade in reverse makes a nice "dozer". You can tilt it like the rear blade to "crown your road or cut gutters. I find it my most used implement next to the FEL.
   / Rent a box blade or a rear scrape blade? #5
Personally if I had such a small amount of material to spread, I'd just use the FEL bucket, backblading to fininsh it off. I could finish off 4 yards of material in the time it took to pick up a rear attachment. If I had to rent something I would probably go with the rear blade since it is asier to use and because you can angle it, it would probably spread it out quicker.
Andy
   / Rent a box blade or a rear scrape blade? #6
4 cubic yards of top soil ain't a lot.
Save your money and use a rake and a shovel.
You can have it spread in less time than you can pick up and return either implement.
Save your rental money and buy a box blade when you can.
Pooh Bear
Thanks for the input. My wife and I just moved 5 cu yards of mulch yesterday with a shovel and a pitchfork. While not a lot of mulch, she wasn't real happy about it. I was thinking about how nice it would have been have a FEL on the Beaver III to move that stuff around from place to place. Renting a box blade for 50 bucks is worth it, cause she ain't gonna help me move that much dirt with a shovel. If I have another need for a box blade, I'll guess I'll buy one.
   / Rent a box blade or a rear scrape blade? #8
WHAT!!!!!!!!!!!!!!!!!!!! 5 yds? Have you lost your mind :D . My wife would have laughed at me had I suggested she move 5 yds of anything. Get a nice FEL and bucket. Do it to save your marriage;) .
Bob
   / Rent a box blade or a rear scrape blade? #9
Oh sorry, I guess I just assumed that you had a loader.
Andy
   / Rent a box blade or a rear scrape blade? #10
Ok, I have a loader, which is the most obvious thing to use to move gravel into the ruts I've made in my driveway. Here is my question: Last year I had the crawlspace under my kitchen replaced. As you might imagine it made quite a mess. The dirt next to the kitchen (clay) is all uneven and will be impossible to mow once I plant grass. The semi delivering the block and big steel I-beams drove into my side yard. So did the cement truck pouring the footer. There are huge ruts there, like more than a foot deep. I also need to grade the drive back to the barn. Is a box blade going to be helpful to me? I don't think a rear blade would do much of anything to this mess. I was thinking I would need those sacrificiers on the BB to accomplish anything.
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
BBQ PIT (A50860)
BBQ PIT (A50860)
