patrick_g
Elite Member
BobRip said:Pat, I bow to your greater knowledge. On a business trip, the projector would not start up. It was plugged into an extension cord on a reel. I had them unroll the reel and it started fine. I blamed it on induction as the resistance was the same rolled and unrolled. Was I wrong?
Don't bow too low as SPYDERLK got it closer than I (was I asleep???) regarding the inductance. Most extension cords aren't "twisted pair" but between the counter currents in the two conductors and the randomization effect of the "jumble" of wire the inductance at 60Hz is negligible.
Regarding your projector mystery: Not being there I don't know if there was an intermittent in the extension cord or what but it wasn't inductance preventing the projector from firing up. If there weren't any technically savvy observers then you looked like a genius to the mob.
Any sufficiently advanced technology is indistinguishable from magic. Different audiences require different levels of technology before they claim MAGIC.
To get significant inductance the extension cord would have to be separate conductors inconveniently wound in series.
I have various reels for storing cords but none will hold over 100 ft and none have multiple cords on them. I tend to unroll more than I need to reduce heating if using a heavy draw on the cord.
I don't recall which magazine it was (I read several that have "clever hints" in them with suggesters winning prizes) and one of them was the bucket cord storage idea.
SPYDERLK and I agree, it seems, that heating is the hazard, not inductance.
HF and probably Cumins Tools, Northern, etc have open wire cages with a crank handle for storing an extension cord in a random jumble. The wire cage will not hold the heat as much as a bucket and the relatively open jumble won't hold the heat too badly. They are handy because you can crank a handle to quickly store the wire and just pull to get it out. (They don't get fouled often.)
Bird, Not putting your boy down, in general I see many PROFESSIONAL contractors doing lots of unsound practices, some out of ignorance and others knowingly because they accept the tradeoffs.
I admire the contractors who use a simple crochet chain stitch to neaten up their cords often repeating the process to really make compact storage. The wire always feeds back out neatly and the bundled wire is not too prone to overheating if used while partly compacted. I use this sometimes but more often coil the cord as a sailor coiling a line to be hung up (not nearly so handy as the crochet stitch but a habit from years of sailing and line handling and the finished product hangs up more neatly.)
SPYDERLK. thanks for the reminder... well du-uh... I guess I know at what age senility begins...
Pat
