Rolled my 3240, and it ran till it blew ??
   / Rolled my 3240, and it ran till it blew ?? #41
Well it appears I'm a very lucky in more ways than one......
WOW That's a good as it gets :)
BTW which side did it roll onto. I'm trying to visualize the path the oil would take to get into the air intake.
Talon Dancer
It went over onto the Right side, opposite the step
   / Rolled my 3240, and it ran till it blew ?? #43
Makes sense. The air intake tube (from the filters) is on that side of the engine. So it would be low when the tractor rolled to that side.
Talon Dancer
   / Rolled my 3240, and it ran till it blew ?? #44
Glad it worked out for you! - Had to have been the longest 10 minutes of your life but maybe not longer than the nanosecond as you turned the key today.
I agree that the oil probably wasn't makin it past the rings - Not enough to keep it running.
The real question won't be answered for years and that is how much wear was done to the engine in that 10 minutes but I suspect not too much since you were running synthetic.
   / Rolled my 3240, and it ran till it blew ?? #45
Hmmm... The value cover would have been up and the air intake down. Not good :(
Looks like the breather hose needs to be longer and take a big detour over the top of the valve cover.
Talon Dancer
   / Rolled my 3240, and it ran till it blew ?? #46
Great news Steve! Glad you are OK!!:)
   / Rolled my 3240, and it ran till it blew ?? #47
That's great to hear. Glad you are no worse for wear, and hopefully your 3240 had no long term issues either.
   / Rolled my 3240, and it ran till it blew ?? #48
Glad to hear it Steve, boy these engines are tough!
Sounds right, I'd say oil got sucked up through the intake.
Be careful!!
Rob
   / Rolled my 3240, and it ran till it blew ?? #50
I'm wondering if a air cut off would work. That engine is going to try and pull air from somewhere and it might suck it right out of your engine through the crankcase breather. I could be wrong but I know I'm not willing to try to find out if I'm right.
Still glad to hear you got out of it safe and cheap. All in all other than some lost sleep not a bad day.
Giyi 48" Mini Excavator Root Rake (A56469)
Giyi 48" Mini...
2018 Autocar ACX Xpeditor T/A EZ-Pack Hercules 40 Yard Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2005 Ford Taurus SE Sedan (A55853)
2005 Ford Taurus...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2014 Crossroads Sunset Trail ST33PB14 36ft. T/A Travel Trailer (A55853)
2014 Crossroads...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
