Oil & Fuel Running Sluggish
   / Running Sluggish #1
viper318
Mahindra 3325
I have changed the fuel filters and fuel. When i start it up and give it more gas, it starts to run sluggish and is putting out white smoke. Is there something i'm missing? Is the pump going bad? Can anyone help.
   / Running Sluggish #2
Check your fuel line for an air leak or maybe an obstruction due to being pinched.
larry
   / Running Sluggish
Thanks for the info. I have already taken all the fuel lines off and blow them out. All lines are good.
   / Running Sluggish
I blew the filter off and nothing didn't come off. Filter looked pretty clean. I have taken the main air line off to the air filter can and started it that way. Still nothing.
   / Running Sluggish #6
viper318, what type of gas engine?
   / Running Sluggish #7
Check and see what kind of fuel flow you have from the tank. Been alot of problems with debris in the tank screen.
   / Running Sluggish
Diesel.
   / Running Sluggish
Thanks for the suggestion civesnedfield. I will check the tank out to see if there is any trash.
   / Running Sluggish #10
Easiest way to tell on mine is to remve the filter then open the shut off valve. If you have a weak fuel stream then the strainer is clogged.
2015 Nissan Quest Van (A48082)
2015 Nissan Quest...
UNUSED Garden Hose 164 ft. (A50860)
UNUSED Garden Hose...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
2013 Jeep Grand Cherokee SUV (A48082)
2013 Jeep Grand...
2021 23ft Cypress Cay Seabreeze 232 Pontoon Boat with 23ft Single Axle Trailer (A48082)
2021 23ft Cypress...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
