superstevek1
Recently acquired older 1972 IH Farmall 140, manual states SAE 30 oil ok to use 10W-30 or 10W-40 or stick with SAE 30 or does it eve matter? Thank you!
Exactly.Modern 10w30 oils do not have the zinc needed for old engines with flat tappets. Most cam companies recommend a 15w-40 diesel oil for the higher zinc content.
OPE oils are typically formulated for air cooled engines operating at higher temperatures and carry a higher price point than a generic C rated 15w40 oil.Those who are concerned about zinc in something like this should consider buying outdoor power equipment oil. I'm no expert on your tractor, but I would think a multi grade would be better for cold weather.
This is a copy and paste "SAE 30 and 10W30 aren’t the same. SAE 30 is an oil that has a viscosity of 30 at overly high temperatures. The 10W30, on the other hand, has a grade 10 viscosity at low temperatures and grade 30 viscosity when the temperature is high. "Recently acquired older 1972 IH Farmall 140, manual states SAE 30 oil ok to use 10W-30 or 10W-40 or stick with SAE 30 or does it eve matter? Thank you!
