screw driver inside tubeless tire
Status
Not open for further replies.
   / screw driver inside tubeless tire #11
The kid said:
This may be dumb question. But why would you balance a tractor tire? Unless someone added some weird tractor tire weights to only one sector of a rim. I just don't see the need. They don't spin fast enough.
Maybe he ment to say ballast. That would make scence.
   / screw driver inside tubeless tire #12
Back in 60's and 70's some farmers used powered lead for balast in tires (before EPA). If you were roading tractor an hit a pot hole or dumped the clutch at high RPM the lead would shift and you had a clown tractor un till you found another pot hole to shake it up and get it resetlled.
Found gloves and tire gauge and walet at different times when i worked on trucks and ran a station with my Dad.
   / screw driver inside tubeless tire #13
i've seen lead shotgun shot put in a tire.. and after a few years use much of it was powder.. :)
no rust on the rim though!
   / screw driver inside tubeless tire #14
Never knew it started as shot only saw it when it was flat and a pain in the butt ot fix.
I went to good year tire service and had them retreive my screw driver. thanks to all with your advise have a safe tractor day
   / screw driver inside tubeless tire #16
There has been no mention of this being a tractor tire, so my response covered automobile and truck tires also.
   / screw driver inside tubeless tire #17
i figured it could be either.. but when I think of tubeless.. I almost forget to think about tractor tires.. :)
   / screw driver inside tubeless tire #18
Welcome to TBN, glad we could be of assistance...and just FYI, I was removing a lawn tractor tire from the rim a few days ago, had to rush off after I got one bead off the rim, and when I went back to finish the job, I could only find one tire lever...anybody got a guess where the other one was? :laughing: Yeah, your thread showed up at the PERFECT time.
   / screw driver inside tubeless tire #19
Cool.................the new guy helped ya.
Great job, retired2002
   / screw driver inside tubeless tire #20
If nothing else, the screwdriver unbalances the wheel/tire. I would remove it and rebalance the tire.
yeah because he will be doing 50 down the highway with the tractor. Whats next, "I was only kidding about balancing the tire"?
Status
2016 Chevy caprice (A55788)
2016 Chevy caprice...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2018 MACK CHU613 DAYCAB (A58214)
2018 MACK CHU613...
2007 Chevrolet Silverado Service Truck, VIN # 1GBHC24K77E577417 (A57453)
2007 Chevrolet...
