Separating the head from the block on a YM3110d to replace a head gasket
   / Separating the head from the block on a YM3110d to replace a head gasket #21
sounds just like mine
   / Separating the head from the block on a YM3110d to replace a head gasket #22
Hit the starter and the compression should pop that head off.
   / Separating the head from the block on a YM3110d to replace a head gasket #23
Awesome, Sounds good! Looking forward to the how to post! +1 on re-check valve adjustment after a while.
   / Separating the head from the block on a YM3110d to replace a head gasket #24
Not a bad idea to re-torque the head bolts while the valve cover is off, too.
   / Separating the head from the block on a YM3110d to replace a head gasket #26
   / Separating the head from the block on a YM3110d to replace a head gasket #27
I would hope if one did that they would have several bolts in and just barely back them out from snug. Not loose so it shoots off like firing and anvil off!
   / Separating the head from the block on a YM3110d to replace a head gasket #28
I'm still picturing a Wile E. Coyote moment :D
New 40ft High Cube 6 Door Container (A59000)
New 40ft High Cube...
SIDE WINDER 14' ROTARY MOWER (A58374)
SIDE WINDER 14'...
Highline Manufacturer BP661-100 (A57148)
Highline...
2019 F150 (A56435)
2019 F150 (A56435)
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
