3-Point Hitch setting the controls on McCormick CX 105 to plow
   / setting the controls on McCormick CX 105 to plow #1
mathmom98
tx
McCormick CX 105
HI,
I inherited the McCormick tractor and have tried to disc and drag a field to level it.
I can not make the disc go into the ground more than half to one inch. (6 foot disc)
I have read to operators manual and can not figure out all the controls.
Today I hooked up a gopher machine and it did the same thing.
How do you set the controls to adjust the depth of the tool?
mathmom98
   / setting the controls on McCormick CX 105 to plow #2
A couple of suggestions:
Make sure your draft control is disengaged. If it's very sensitive, it may be lifting your three-point hitch as your disc begins to cut in. You won't need draft control with a tractor that size and a small disc like that.
Make sure your top link is long enough to allow the disc to actually drop farther into the soil.
If the ground is hard, a lightweight 6' disc isn't going to penetrate well into undisturbed soil. You might need to add weight and/or wait for rain with much of Texas.
2015 DODGE RAM...
1955 FORD COBRA REPLICA RACING CAR (A51222)
1955 FORD COBRA...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A51039)
2015 Ottawa Yard...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
