RickB
Super Star Member
- Joined
- Sep 18, 2000
- Messages
- 15,190
- Location
- Up the road from Dollar General WNC
- Tractor
- Just a Scag
The ground speed should change little to any going to a 18.4x38 since he already has 14.9x38 tires. They may be a bit larger but I don't think it will change the ground speed enough to notice. Dual 14.9's would put a lot more strain on the axles than a singe 18.4 would. The single tire would be much better in mud also unless you have very long axles so you can space the duals at least 12" apart so mud can shed otherwise they will slick over and give no traction in mud.
You will need to replace the rims also for the wider tire. I don't think they would work on a 14.9 rim.
Ground speed will increase a little over 10%. Whether that is noticeable is open to debate. It is a consideration especially in operations where decreasing throttle is not an option.
