Size of the nuts on 3 pt lower pins?
   / Size of the nuts on 3 pt lower pins? #1
Coyote
North Carolina
Yanmar 2000B & Skat Trak 1300D skid steer
I have to replace the lower pins on my disks. Anyone know the size nuts are used? I know they are bigger than 1" from past experience, anybody know? BTW - TSC has pins on sale for $2.25 right now. Thanks!
   / Size of the nuts on 3 pt lower pins? #2
I believe nuts and lock washer are supplied w/pins.
   / Size of the nuts on 3 pt lower pins? #3
I have two sizes of category I threaded shanks on my equipment. The smaller and most common is 7/8" shank with a wrench size of 1 1/4" I also have some with a shank size of 1 1/8" and wrench size of 1 5/8"
   / Size of the nuts on 3 pt lower pins? #4
Big ol' adjustable wrench has worked for me.
   / Size of the nuts on 3 pt lower pins? #5
If your pins and/or tractor are made offshore you may have to use a metric adjustable..... /forums/images/graemlins/grin.gif
   / Size of the nuts on 3 pt lower pins? #6
Maybe they have wrenches on sale too, to fit your new pins. /forums/images/graemlins/smile.gif
The nuts on my box blade need an 1 3/8" wrench, the one I don't have. I do have an adjustable wrench that fits.
   / Size of the nuts on 3 pt lower pins? #7
COnsider this your one excuse to but that big honkin monster adjustable wrench that you always loved when you were a kid. Lots of chrome. Great hammer too. The trick for me is holding the pin still while trying to unthread that big ol nut. The only way was by shoving something through the lynch pin hole which is pretty small. Maybe an impact wrench might do well here.
   / Size of the nuts on 3 pt lower pins? #8
That's what I got, the big ol' honkin' Cresent...guaranteed to fit anything up to 2". There are lots of places it wont fit. /forums/images/graemlins/frown.gif
I use a larger tapered punch to hold the pin in place, about 10" sticking out of the hole to work with. Of course a spud wrench would work well too.
   / Size of the nuts on 3 pt lower pins? #9
Pipe wrench on the pin, crescent on the nut.... If the pin is shot you could weld a "handle" on it to stop it turning. /forums/images/graemlins/cool.gif.The heat involved might even help to break it loose.
   / Size of the nuts on 3 pt lower pins? #10
27mm and 30mm sockets are REAL HANDY sizes to have around, corresponding approximately to 1 1/8 and 1 1/4, but a MUCH better fit on just about everything that is made almost anywhere these days - are we in a Metric world yet ? (-:
1/2 inch drive if thats all you have, 3/4 inch preferrred.
Or should I say 12.7 and 19 ?
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
5 Printers (A48083)
5 Printers (A48083)
2020 Case IH Farmall 130A Tractor (A50860)
2020 Case IH...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
Ozone Trickster Bike (A50860)
Ozone Trickster...
