Skid plate for GC series tractors
   / Skid plate for GC series tractors #61
Plastic isn't a bad idea. I just did an install job for a winch and plow to a friend's Yamaha ATV and it uses end to end skid plates made of plastics. The only real issue I see there is the weight of a tractor is unforgiving and the plastic plate would take all the force. This would be especially concerning when doing something like brush hogging. I've read a few threads where a rogue stick jams a radiator and ruptures it which is tougher stuff than plastic.
   / Skid plate for GC series tractors #62
If you're considering plastic(s)... consider UHMWPE -- ultra-high molecular weight polyethylene. That stuff is amazingly tough, and is often used for snowplow scraper blades. I used it to line the impeller cavity and chute on my snowblower, where it made an amazing difference. It can be ordered in sheets of desired thickness (I used 1/8" for my project), and can be shaped by using a high-heat gun or even a small torch. Heat up just below melting, bend, let cool.
That material, plus perhaps some metal stiffeners here & there, might just work!
   / Skid plate for GC series tractors #63
View attachment 625618View attachment 625619
Nice job lining your discharge chute, I still have the UHMW pieces saved in an online basket, just have not put that project at the top of the list yet.
KC
   / Skid plate for GC series tractors #64
Looks like it is a tuff plastic, is it spendy? I would think a rosebud could be used to heat it up and bend it how you want it then cut slits in it where the MMM lift arms line up and make a metal tab bracket and bolt it to the plastic, I have a pic in my head how I would do it and I believe it would work but as far as now goes I am going to use iron this first time around.
Thanks for the heads up on the UHMWPE.
   / Skid plate for GC series tractors #65
Another crappy day here in west central Mn so I did not get anything done as far as the plate goes, will see what tomorrow brings.
   / Skid plate for GC series tractors #66
I work at a metal fabrication shop skid plates are or something that I always wanted to do for my gc1715. So maybe in the next few weeks I can dig into it and fabricate something up get a laser cut out and if people are interested enough make a few sets.
I have the capabilities of laser cutting machining forming welding so we'll see where this takes me.
If I develop anything I want a skid plate that goes all the way from the front axle that protects all the vitals much like aftermarket Jeep Wrangler skid plates. Does the spark interest?
   / Skid plate for GC series tractors #67
I agree... My biggest concern up front is the steering system and those boots/seals. Then you have hoses and wiring in the middle and hydrostat fan and filters towards the back. Important stuff all along the underbody.
   / Skid plate for GC series tractors #68
Thanks, irvingj, that looks like a good solution to the issue. I did a search for it, it's not cheap, but the saying goes "Good isn't cheap and cheap isn't good."
It should last many years .
Sorry for the delay. It's pretty simple and I remove it in the winter to hook up the front driveshaft for a snowblower. Have to also remove it for changing the filter but it's only 4 bolts. I made it out of a scrap of steel of unknown parentage that I had laying around. Lots of big rocks around here and it held up real well. I bent it by heating the bends with a rosebud torch until it bent fairly easily. I don't use a mower. The skid plate cuts down the ground clearance under the rear differential by maybe an inch and so far hasn't been an issue.
Yeh cool, looks legit and easy to fab.
You got it, just like a deck, it has been a crappy day here with high winds and rain so I did not get to town but my wheels showed up for my MMM dolly and again to crappy outside to open the garage/shop door and lift the mower deck up to fit the axles, the wind and rain are blowing right at the door.
Sweet.
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A55851)
Tiger Mowers 80in...
ROCKWELL INTERNATIONAL 8' 4" T/A DOLLY (A57192)
ROCKWELL...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2012 Chevrolet...
2015 ISUZU NRR DEBRIS TRUCK (A57192)
2015 ISUZU NRR...
2022 Caterpillar 259D3 (A53317)
2022 Caterpillar...
2020 DRAGON ESP...
