Snowblower - too big?
   / Snowblower - too big? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
Is there such a thing as too big for a rear-mount snowblower, other than powerwise? I have a lead on what seems to be a good deal on an absolute beast of a blower, but it is 7' wide. My L4200 has the horsepower to run it, but my driveway is only ~8-9ft. wide (but 1000' long). For a simple once up and back job, 5' is plenty, but my rear tires are ~5.5' wide, so I was looking at 6 footers. Anyway, I came across a used 7 footer, and I wonder if 6" on each side makes much of a difference one way or another. Is bigger always better?
thanks - JayC
   / Snowblower - too big? #2
HP and weight are the two things you need to worry about-You said you have the HP covered, but will your 3PH lift this "absolute beast of a blower"?
   / Snowblower - too big? #3
thanks - JayC
IS the L4200 a gear tractor? I'm running a 6.5' blower on an L3710 HST. I wouldn't want any more of a blower on this tractor, but it does a great job. I've had the blower for 12 years. Normally I blow in mid range, if the snow is deep and very wet, I have to go to low and creep into the drifts.
   / Snowblower - too big? #4
My tractor is a lot smaller than yours, but I run a 6 ft. wide rear blower with 22 HP at the PTO. I have absolutely no problem with power (HST) or lift capacity. I also use the FEL for snow clearing and it has a 54 inch bucket. I have to be very careful that I don't sideswipe things with the blower while using the FEL.
   / Snowblower - too big? #5
.....Is there such a thing as too big for a rear-mount snowblower.......
Yes there is, but this isn't it. The 7'blower is too big for a 24 hp tractor. But it would be just fine on a L4200. Remember you can always go a bit slower if need be. Weight-wise it will handle it fine. You'll like how nice it is to have 9" extra width on each side.
Piece of cake - the blower is something like 625 pounds - according to Tractordata.com, my 3pt lifts over 1.5 tons.
JayC
   / Snowblower - too big? #7
I am considering getting a Frontier SB 1164 and I was considering the SB 1174, but it seemed that the 1174 would be a bit too big. My unit's PTO HP is 30 and the SB1174's spec is 30 - 50HP required, so it seems the 3520 would be a bit underpowered to handle a SB 1174 - any thoughts?
   / Snowblower - too big? #8
JayC. If the price is right, I'd go for it. Unless you're really fond of spending the extra time out blowing snow. Do you have a heated cab? You can always clear a little bigger path, say 12' or 13'. Besides, if you dont like it, you can always sell it.
Wedge
   / Snowblower - too big? #9
I run a 7' with 55 pto hp. only thing I've noticed is the front end steering is lighter. I usually drop the front bucket 8' when running the blower.
I'm beginning to lean that way. Price is easily twice what I wanted to spend originally, but its a nastier machine and (I think) about 1/2 of new. Snowblowers seem to be increasing in price exponentially. A run-of-the mill 6' blower was $1200-1500 new 2 years ago, now they seem to be running about double that, with the good commercial ones ~$5000. The one I'm looking at also runs closer to $5k. Sheeeyit - my tractor barely cost that much.
JayC
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2016 Kia Optima EX Hybrid Sedan (A48082)
2016 Kia Optima EX...
2019 New Holland C227 Skid Steer (A50657)
2019 New Holland...
2017 Chevrolet Silverado 2500HD Crew Cab Pickup Truck (A49461)
2017 Chevrolet...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
