solid plate or expanded metal for bottom of tongue storage on equipment trailer?
   / solid plate or expanded metal for bottom of tongue storage on equipment trailer? #1
disney
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
I recently acquired an old, used deckover that has locking storage built into A-frame, but currently the bottom (1/8 or 3/16) plate is more rust than metal.
What do all you prefer: solid floor/bottom, or expanded metal? Why?
I would likely go with Aluminum if I go solid, but would use steel for expanded metal as I already have some laying around, and could just weld it in place (it's harder to use bolts with expanded metal than plate...)
I promised myself I would not buy an equipment trailer that was gonna be a project, but apparently I only lie to myself!
I hope everyone is doing well, and as always, I thank everyone who takes the time to reply.
I guess I should add, top/lid will not be water tight, but would keep majority of water out, and I would make a few drain holes, If I went solid.
   / solid plate or expanded metal for bottom of tongue storage on equipment trailer? #2
I'd want solid just for keeping dirt, mud, water, salt spray, etc... out.
   / solid plate or expanded metal for bottom of tongue storage on equipment trailer? #3
I’d want solid to help keep my straps dry. That and I hate expanded metal.
   / solid plate or expanded metal for bottom of tongue storage on equipment trailer? #4
I have a trailer with expanded metal and my chains get beat up from road grime. I’d look into installing an aluminum box that locks and is weather tight.
   / solid plate or expanded metal for bottom of tongue storage on equipment trailer? #5
If it were mine I'd want solid but if I were you I'd want expanded. Why not get side mounted boxes so you can have one of each?
   / solid plate or expanded metal for bottom of tongue storage on equipment trailer? #6
I'd go solid with a drain hole in each corner. Trying to get chains out of a box with an expanded metal bottom is a lesson in frustration.............Mike
   / solid plate or expanded metal for bottom of tongue storage on equipment trailer? #7
No matter how well sealed you think a trailer box is all it takes is one heavy rain while your driving down the road and you now have a humidor.
   / solid plate or expanded metal for bottom of tongue storage on equipment trailer? #8
Solid, for me. Expanded is for traction and large items, such as shovels.
   / solid plate or expanded metal for bottom of tongue storage on equipment trailer? #9
I like expanded metal floors. I lay a piece of rigid foam insulation over the expanded metal to quiet things down and serve as a barrier to road debris. The foam is easy to replace and cheap.
I hate to ask (but have to) how does the expanded metal make it more difficult to remove chains? Unless the chain is so small (or the holes so large) that it can fall through. The expanded metal I have/might use has openings only large enough to just put the tip of your finger in, so I can not see 5/16-3/8 chain having an issue??
Thank you for all replies and whichever I choose, I like the idea of some rigid foam to both silence and help protect the chain.
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
Honda EM3500SX Generator (A55851)
Honda EM3500SX...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
