I'm just trying to find out if anybody else had issues with the hydraulic steering hesitating when you try to turn it. When I go to turn the tractor it gets hard to turn I have to stop mowing to turn the wheel and then start again
I assume you checked the hydro fluid level. A low level can cause steering problems on those mowers. A pump going bad could cause problems.I'm just trying to find out if anybody else had issues with the hydraulic steering hesitating when you try to turn it. When I go to turn the tractor it gets hard to turn I have to stop mowing to turn the wheel and then start again
The shaft that the steering wheel goes into a socket that enables the tilt to work needs to be lubricated . I used an old can of STP which worked great when it starts to bind up.I'm just trying to find out if anybody else had issues with the hydraulic steering hesitating when you try to turn it. When I go to turn the tractor it gets hard to turn I have to stop mowing to turn the wheel and then start again
