Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,641
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
I have an 038 from 1986 that is run VERY infrequently. When I start it it runs and will hold an idle too. When I cut Ash and other trees it does not seem to be giving the chain enough oil. When I need it to cut fast it often slows or bogs down, and I have to pull it from the cut and run it fast to get it to regain its power. I'm wondering if it is a carb adjustment due to changes in today's gas vs. 1986 vintage?
Air filter is clean, replaced vent hose off tank- it was soft and fell apart. Completely cleaned all the passageways for the oil to run to the chain/bar.
Stumped
Any thoughts would be helpful. Thanks...
(Also replaced the cam tooth for the recoil starter with the dual tooth style- now it starts when I pull the cord instead of just allowing the cord to pull out with no engine turnover).
Stumped
