Stuff happens
   / Stuff happens #2
Chain, cable, strap.. if any of them breaks under stress they can become lethal. I do more than my share of pulling/towing, at home and at work. I'm extra careful, but if something fails at the wrong time.....:(
My condolences to his family..
   / Stuff happens #3
You gotta be careful when you do stuff like that.
   / Stuff happens #4
Darn shame. :(
   / Stuff happens #5
Slowly replacing all my chains (for towing, pulling) with 2-4" nyloy crain straps.
Nick
   / Stuff happens #6
This puzzles me because I have always heard that it was much safer to tow with chains than straps or ropes because they don't stretch and store up kinetic energy. I heard if a chain breaks it should more or less just drop to the ground instead of whipping back like a stretched rope does.
Could it be that the chain was attached to something else that streched and whipped it back? Or could the driver have made a sudden jerk instead of a steady pull? I go very slow and easy when pulling with chains and I sure hope I am not exposing myself to more danger than expected.
   / Stuff happens #7
Op1 to op2 "just give it a good yank"
Tom in Vermont
   / Stuff happens #8
With chains, you don't really see the visible stretching but there is some. And of course what ever is pulling on it, will also move forward a tiny bit when the chain breaks. As a volunteer firefighter, one of the grass fires we fought was the result of a loaded dump truck trying to pull a stuck mobile home mover truck with a chain. When the chain broke, it knocked sparks off some rocks and started the fire. Or at least that's what the truck drivers told us, and I think they were telling the truth.
   / Stuff happens #9
I've sometimes wondered why people don't run something like 1/8" aircraft cable through the 3/8" chain links. If the chain breaks the cable will contain it most likely, and anything with enough force to break 3/8" chain will shrug off 1/8" (the 1/8" in turn will be contained by the now sagging weight of the 3/8" chain links once the 1/8" cable slack is taken up).
This is the same sort of idea as running 1/8" through the linear springs of garage doors to stop the broken spring pieces from flying around when the springs inevitably break under tension.
   / Stuff happens #10
Reminds me of that gag pic of the "OSHA" approved horse.
John
UNUSED 20 in. Gasoline Chain Saw (A50860)
UNUSED 20 in...
2014 FORD F-250 (A50854)
2014 FORD F-250...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
PETTIBONE B66 EXTENDO (A51222)
PETTIBONE B66...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
