Stupid Myers plow....
   / Stupid Myers plow....
They ALL suck a battery down quick if you do alot of lifting and angling. Unless you have a aux. belt driven pump powering the rig. Fortunatally, the only time I ever killed my battery in my plow rig was when I left it in float after I was done plowing. Left the A-coil energized and I had the plow controls wired to 12v hot-at-all-times. It wasnt until 3 or 4 days later when I needed the truck again. And yep, dead. On my new rig, I tied the controls to hot-in-run-only power. So it wont happen again:mur:
So does that mean it works now? What was the issue you think? A new C-solenoid WITH coil is only $78
I am thinking it was the 3 wire harness, possibly an internal short. I religiously use dielectric grease (actually still have a HUGE tube of it I "acquired" from the Air Force while in the Army...heh-heh) so I am guessing it was intenal on the plastic connector end. I used new male and female bullet connectors so no more 3 wire connector, now each has it's own seperate circuit/ run.
Unfortunately broke that stud, so simply tacked it back on. All works now, just waiting on the white stuff.
Soooo, go to use the F250 with the Fisher today, make my first pass, go to back up, and no lift, turn nothing! Bad ring connector on ground wire from controller to solenoid....:confused2:
If you'll excuse me I now have to eat some crow......:laughing:
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A59575)
2018 KAUFMAN 44 FT...
2022 Ford F-450 Super Duty STX Pickup Truck, VIN: 1FT8W4DT2NEC20764, Crew Cab, 4x4, Fx4 Off Road, (A59076)
2022 Ford F-450...
UNUSED FUTURE...
LOT: Assorted Hammers (A59076)
LOT: Assorted...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A57453)
2007 Hino 268...
