WoodChuckDad
Elite Member
- Joined
- Jul 15, 2015
- Messages
- 2,714
- Location
- Free Union, VA
- Tractor
- Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
I need a rotary cutter. I finally have managed to grow a mixture of fescue, rye, clover, buckwheat and rape in my orchard and in another field that we are trying to get ready for planting. I had to cut all the flowering plants down in the orchard, so I could spray for beetles. (don't want to kill off the bees). All I had to work with was a wheeled string trimmer and a residential walk behind mower. I also had to mow the **** next to my pond. all in all it was more than 6 hours and it was bloody hot. A rotary mower could have done this in an hour, not counting hookup. And I would have been in Air conditioning. It's time to spend the money and get a cutter. But my problem is how heavy do I go. I have about 25 acres that were clear cut 2 years ago. Mother nature is trying to make a comeback on a fair amount of it. I will use the cutter on fields and in the orchard. I am leaning toward a 7 foot 3 point mower. I have lots of stuff growing all over mystery property (55 acres total), but because it was clear cut there is a lot of stuff with stumps so I will most likey go thru with the excavator popping stumps on the rest of the property first, before it ever sees a mower. So do I need the monster heavyweight cutter that can cut 3 or 4 inch material, or will a medium cutter that can handle 2 inch material do me just fine? I have looked at the woods BB84x (2 inch material) and the BB840X (3 inch material). There are a few others out there that go even heavier, according to their spec sheets. The difference is 2500 vs 4500ish. If I am never going to use that extra oomph from my�� 73 ?HP tractor (63 pto) then I would rather keep the money and use it on something else.
edit for clarity--Apparently I was not clear about my situation. I have about 30 acres clear cut. Then had bulldozer push most debris into windrows. Some stumps came up when dozing was done. I have a 30,000 lb excavator and I have been pulling stumps to clear areas that we want to plant apple trees in. Currently we have planted 500 trees and I anticipate a few thousand more over the years. I would not try to run the rotary cutter over areas that still have stumps, and I would get all the slash up before running across any of it as well. Even after you pull stumps lots of stuff tries to grow back. So you get thistle and briars and thorns and volunteer trees that pop up from root systems that havn't been completely removed. What I'm wondering is if something like a Woods BB84x would be sufficient for my needs or if I will be sorry that I didn't go heavier. IT is rated to handle 2 inch material. I would mostly be using it to mow over fields that have grass or upto 2 foot tall green manure type or nitrogen fixing type plants that we are using to condition the soil l. There are times that the forest starts growing back right beneath. you when you leave a field to nature for a while.
I agree that a twinn rotar setup would be more maneuverable but also less powerful from what I read. And it would be almost double the price.
